  3. IC 6.14: How to write to the status line of a edit-window...
  • Replies 10
  • Views 17823
IC 6.14: How to write to the status line of a edit-window?
StefanSL
StefanSL over 15 years ago
 Dear all,
i'm desperately looking for a possibility to write commands or status messages to
the status line of a design window, but without luck until now, neither the documentation
nor this forum were very helpful;
currently i'm writing output to the user  to the CIW, but i'm not happy with that cause
quite often you don't have the CIW directly in your field of vision, so my users have been
waiting for something to happen whilst virtuoso was waiting for some input...
 any possibility to put my messages to the status line of the design window?
thanks for your help
Stefan
    How about using hiChangeBannerLabel ?
  • StefanSL
    thanks for your fast response;
    using
    hiChangeBannerLabel(hiGetCurrentWindow() "STEFAN2" 0)
    i can change the label or add labels at the lower right corner of the window, to the right
    of the "Cmd:"-label, but i cannot write to the lower left part where virtuoso usually shows
    command to the user;
    are there more options to hiChangeBannerLabel, did i miss something or is there
    another command available?
    this solution is much better than writing to the CIW, but... i'd prefer the opposite corner :-(
    kind regards
    Stefan
    Hi Stefan,
    If it was an enter function (e.g. enterPoint, enterBox), you could set the prompts which will guide the user.
    Other than that, I think you're constrained to use the banner labels - I don't think there's a function to set the left side of the prompt bar.
  • StefanSL
    thanks for your assistance.
    I want to display commands and status-messages for my own
    procedures, so i'll have to accept this limitation - what a pity!
    best regards
    Stefan
    Hi Stefan,
    Of course, you could always log a service request via customer support and then an enhancement could be requested for this ;-)
    Best Regards,
  • dmay
    dmay over 15 years ago
    How about:
    setPrompts("My Prompt" "")
    Although this prompt disappears during enter functions.
    Derek
  • StefanSL
    Hi Derek,
    many thanks, just tried "setPrompts()", this command exactly does what i was looking for :-)
    And the content of the status line persists longer than required, i have to reset it myselves...
    kind regards
    Stefan
    Derek,
    I probably should have mentioned that; I'd discounted it because it's not per-window but common across all windows. However, I guess it depends on what Stefan wants - I shouldn't have made assumptions!
  • StefanSL
    you were right, i just wanted to display my message in the current window,
    but this shouldn't be a major problem;
    i'm just coming across a somewhat strange behaviour when repeatedly changing
    the prompt, but i don't know yet where to look for the cause, i have to insert some
    lines of println()-calls to debug my code...
    regards
    Stefan
  • StefanSL
    the problem i've mentioned above is as follows:
    when setPrompts() is run manually, from the CIW, the prompt will follow the
    command  without any delay; if i run my script repeatedly, the prompt
    seems to remain unchanged although i set it to the desired output and
    afterwards i set it back to "" or ">".
    In fact, the prompt is changed but not shown immediately, the change
    becomes visible when the user interacts with the design window;
    cause i want to use this message as a command to the user, this approach
    is not sufficiently reliable, i should stay with Andrews proposal to use
    hiChangeBannerLabel()...
    kind regards, many thanks for your support
    Stefan
