  3. ocean issue in OA
  • Views 14692
ocean issue in OA
VictorB
VictorB over 15 years ago
When I start from virtuoso(OA) with the command,
sh( strcat( "setenv SHELL /bin/ksh; chmod +x ./ocean/ocean_runner; xterm -T 'Ocean runner' -geometry 120x30+150+40 -fn *-fixed-*-*-*-20-* -e 'cd ocean; ocean; bash'&" ) )
the library manager loses the link to all libraries, they disappear .The libraries will reappear when restarting the library manager.In cadence 5 there was no issue. The command above launches a xterm and starts ocean, leaving out the last command ''ocean'' to start ocean, then there’s no issue
.sh( strcat( "setenv SHELL /bin/ksh; chmod +x ./ocean/ocean_runner; xterm -T 'Ocean runner' -geometry 120x30+150+40 -fn *-fixed-*-*-*-20-* -e 'cd ocean; bash'&" ) )
I hope someome can help,
rgdsRobert
    The problem is probably because of the child process inheriting the "MPS" session information from the parent, which is confusing communications between the tools. Try passing "-mpssession dummy" or something similar as an argument to "ocean".
  • VictorB
    Thanks Andrew,
     passing "-mpssession dummy"  solved the issue.
    regards
    Robert
