  3. Merging shapes non-interactively
  • Views 20356
LostInRTN
LostInRTN over 15 years ago
I need to use the merge function in a layout via a SKILL program. Doing this interactively is easy- select everything and select "merge" from the menus. How is this done without opening a window? I don't see the merge function in the db or dd functions reference. I can open it with dbOpenCellViewByType, then what?
Tom Spargo
    Andrew Beckett over 15 years ago +1
    Hi Tom, I've also found that sometimes it's better to use dbLayerOr() (with a single list of layers) to merge the shapes, and then discard the originals - in some trials I did a while ago, this had better…
  • skillUser
    skillUser over 15 years ago
     Hi Tom,
    Although I have already answered this for you via a Service Request, I will answer this here for the benefit of others.
    The leMergeShapes command can be used in a non-graphical fashion, here is what I did to test this. First I created the cellview "leMerge" in library "test" and then created some overlapping shapes. I interactively tried the command and then reverted to the previously saved version and closed the cellview. Then I performed the commands non-graphically:
    ;; open the cellview in virtual memory, non-graphically
    cv = dbOpenCellViewByType("test" "leMerge" "layout" "maskLayout" "a")
    =>  db:243736620
    ;; perform the merge command on all of the shapes
    leMergeShapes(cv~>shapes)
    =>  (db:243736828)
    You might want to only merge certain shapes rather than all of them, in which case it would be useful to apply a pre-filter, for example to merge only the shapes on the metal1 layer:
    leMergeShapes(
      ;; take the first (hopefully the only) result from 'setof'
      car(
        ;; filter through the layer-purpose pairs to find the "metal1"
        ;; layer - here I'm assuming only one purpose is used, but the
        ;; purpose can be matched explicitly also by adding to the
        ;; condition:  && purpose=="drawing"
        setof(lp cv~>lpps lp~>layerName=="metal1")
      )~>shapes
    Best regards,
    Lawrence.
    Hi Tom,
    I've also found that sometimes it's better to use dbLayerOr() (with a single list of layers) to merge the shapes, and then discard the originals - in some trials I did a while ago, this had better performance than leMergeShapes with a large number of shapes.
    I used this approach in solution 11328674
    Best Regards,
