  3. frequency sweep variable - ocean script
  • Views 2499
C4n0s4
C4n0s4 over 15 years ago
Hi! Im trying to plot the inductance vs frequency using ocean. The problem is that i cant find the variable frequency. I tried "frequency" , "freq", ... What is the name of variable reponsible for the frequency sweep? my code: Y11_re = real(yp(1 1 ?result "sp")) Y11_im = imag(yp(1 1 ?result "sp")) L_ind = (1/Y11_im)*(2*pi*frequency) '( "L" ) ) Best regards Canosa
    Use frequency=xval(sp(1 1 ?result "sp"))  - this will get the x-axis from your s11 - which will be the frequency axis. So if you then include that in your calculation, it should do what you want.
  • C4n0s4
    Tanks a lot Andrew! I was able to put it on... Now im, just having one problem... i want to put the L and Q at the same subwindow. But two axes, at left and right side of the subwindow. It's that possible? Until now im calling two plot functions separated, one for each parameter. But how to put the right axes? Thanks again Canosa
  • C4n0s4
    I have managed to buid the plots. Thanks a lot
