  3. How to traverse the hierarchy in a schematic
  • Subscribers 152
  • Views 23741
aryajur
aryajur over 15 years ago
         I am totally new to SKILL. I am trying to write a skill routine to traverse the hierarchy of a schematic. Basically I want to pick each port at the top schematic and go down the hierarchy tracing each net down the hierarchy and listing out to which pin it connects to for certain type of components.
        What functions can help me in:
1. Listing out the ports on the schematic
2. Listing out the subcircuits in the schematics that I can open and go inside
3. Trace a net to find the components connected to it on a particular schematic.
Thanks.
  • Quek
    Quek over 15 years ago
    Hi aryajur
    Hope that solution 11685440 can give you an idea of how to transverse a schematic design. Maybe you can start from there. : )
    This is the part that does the transversing. It calls a procedure recursively.
          foreach( master cv~>instances~>master
    nextCv=master
    cond(
    (!nextCv nil)
    (member(nextCv masterList) nil)
    (t
    nextCv2=dbOpenCellViewByType(nextCv~>libName nextCv~>cellName "schematic" "" "a")
    getWarn()
    when( nextCv2
    masterList=CCSfindAndChange(outPort nextCv2 pattern
    checkAndFix ignoreBusInst cons(nextCv list(masterList)))
    ) ;when
    ) ;t
    ) ;cond
    ) ;foreach
    Best regards
    Quek
  • aryajur
     Hi Quek,
               Thanks for your reply. That helps a lot. I also found that cv~>terminals gives me all the ports on the schematic. Only thing remaining that I cannot find still is #3 i.e. to trace the connectivity down the hierarchy. Is there any solution that shows how you can generate a custom netlist. I guess that will show that.
              Another thing I don't understand is what is the difference between cv~>instances and cv~>instances~>master. Both give different database IDs but when I compare cv~>instances~>cellName and cv~>instances~>master~>cellName they are both the same.
  • Quek
    Hi aryajur
    I think perhaps you can use the following method to trace schematic net connectivity:
    a. Find all instances and terminals connected to the net using the script below
    b. Open each of the instances and repeat step "a"
    "cv~>instances" gives the list of instance IDs. "cv~>instances~>master" gives the cellview ID of the master cell from which the instances where created. E.g.
    cv=geGetWindowCellView()
    cv~>instances~>name
    ("M2" "M1" "M0" "M7" "M6"
        "M5" "M4" "M3" "PIN4" "PIN1"
        "PIN0" "PIN3" "PIN2" "R2" "R3"
        "R0" "PIN5" "C0"
    The above gives the instance names. But if I were to do this:
    cv~>instances~>master~>name
    I will get "nil". It is expected that both "cv~>instances~>cellName" and "cv~>instances~>master~>cellName" are the same since it is the same cell that is being used. Cell "abc" is used to create instance "I0" in a schematic. The name of the cell master is still "abc". : )
    Best regards
    Quek
    procedure( CCSgetNetObj(myNet)
       prog( (cv allInsts instList term allTerminals)
          allInsts=cv~>instances
          allTerminals=cv~>terminals
          instList=list()
          foreach( inst allInsts
             when( member(myNet inst~>instTerms~>net~>name)
                instList=cons(inst instList)
             ) ;when
          ) ;foreach
          term=car(setof(x allTerminals x~>net~>name==myNet))
          if( term then
              printf("Net %s is connected to instances : %L and terminal : %s\n"
            myNet instList~>name term~>name)
          else
              printf("Net %s is connected to instances : %L\n" myNet instList~>name)
          ) ;if
          return(list(instList term))
       ) ;prog
    ) ;procedure
    getnetobj.il
  • ron2015schmitt
    ron2015schmitt over 8 years ago in reply to Quek
    Hi Quek,  The link you provided is now dead.  Any idea if the mentioned solution is still around somewhere?  Thanks, ROn
  • Quek
    Quek over 8 years ago in reply to Quek
    Hi Ronald
    Here is the updated link:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nZ36EAE&pageName=ArticleContent&sq=
    Best regards
    Quek
