  3. How to merge Tables?
  • Views 16291
Messi
Messi over 15 years ago
  i have two tables say : my1[a][b] and another table my2[a][c]. I would like to merge these two tables so that my output looks like : ie new merged table be : my[a][b,c]. So that when i say my[a][b] it should have contents of my1[a] [b] and when i say my[a][c] i have contents of my2[a][c]. Is this possible?? Hope you all got my question.
Messi
    Hi Messi,
    Your question is not entirely clear, but this should just be a matter of doing:
    my[a][b]=my1[a][b]
    my[a][c]=my2[a][c]
    This is assuming that my[a][b] is returning a table. Note that it's not a copy of the table, but a pointer to the same table - so they will remain linked.
    If I've not understood your question properly, I think you'll need to elaborate a bit more.
  • Messi
    Thanks for the quick reply.My requirement is as follows:
     I make a table called my1[a][b] using makeTable similarly i make another table my2[a][c].
    I want to use my1[a][b] and my2[a][c] as key and make a new table such that it is my[a][b,c] ie [a] is taken common from both my1 and my2 tables whereas [b,c] should have merged contents of [b] and [c].
    So my new table would look like my[a][b,c] ie it would something like my[a][b] = my1[a][b] and my[a][c] = my2[a][c].
    Hope its clear.If my requirement is junk.just ignore...Thanks :-)
    Messi
    Hi Messi,
    You've unfortunately just said the same thing you said before, without giving any more detail. Did my previous answer not solve the problem then?
    Perhaps if I illustrate with an example:
    my1=makeTable('myTable)
    my1['a]=makeTable('myTable)
    my1['a]['b]=makeTable('myTable)
    my1['a]['b][1]="hello"
    my1['a]['b][2]="world"
    my2=makeTable('myTable)
    my2['a]=makeTable('myTable)
    my2['a]['c]=makeTable('myTable)
    my2['a]['c][1]="testing"
    my2['a]['c][2]="123"
    then:
    my=makeTable('makeTable)
    my['a]=makeTable('makeTable)
    my['a]['b]=my1['a]['b]
    my['a]['c]=my2['a]['c]
    You can then do:
    my['a]['b][1] => "hello"
    my['a]['c][2] => "123"
  • Messi
    Hai,
    Thats it...thats want i wanted.Thanks for the help.Maybe i couldnt get your first post properly.:-)
    Really love this forum.:-)
    Messi
