  3. how to access via parameters (IC5.1.4)
  • Views 15762
lrl12skdev
lrl12skdev over 15 years ago
Hi All Cadence Specialists,
I have a slight problem in my code so I would appreciate very much if anyone can help.
I am using IC5.1.41 and my code is dealing with Contact/Via
part of the code is to extract some values like delX, and delY, I did not create my own form for inputs like this so I just reuse the internal form "le0ContactForm". My problem is, if I have just started my icfb session, le0ContactForm->delY->value returns nil, only when I use the create Contact function that the value becomes available. My assumption is that the fields in the "le0ContactForm" are set to nil and will only be initialize once you press the bindkey "O" (for create contact).
Is there any possible work-around with this?
In IC6.1 I know I can acces this by techid~>viadDefs~>params
Is there a similar way to do this in IC5.1.4xxx?
best regards
lrlsk
  • dmay
    dmay over 15 years ago
    It sounds like you are pulling up the Create Contact form and want to access fields on the form and it will only work after the form is defined. Here is a work-around I use to set a button on the Search form:
    hiRegTimer("leSearchForm->searchZoomToFig->value =  t" 1) leHiSearch()
    The hiRegTimer delays the command to run 0.1 seconds in the future, giving time for the leHiSearch to start and create the form. This allows the command to work for a defined or undefined form.
    Thus:
    hiRegTimer("myVar = le0ContactForm->delX->value" 1) leHiCreateContact()
    However, for this specific case, it sounds like what you really need is one of these commands:
    leGetContactDefaultParam(cellViewId)
    leGetContactParam(instId)
    leGetContactRule(cellViewId)
    Look these up in the documentation to find their return values.
    Derek
  • lrl12skdev
     Hi Derek,
    Many thanks for your reply. I am glad you understand very well from the short description I had given. However I don't think that it is a problem with timing/delays because the function I have written is interactive. I used enterbox function to get two points from the user then it will fit into this box the requested via instance. It is also a possibility that I may not want to use the default parametrs of a via, for example I might want to increase the spacing of vias for more relax via density so I don't know at the moment how to benefit from the three functions you have mentioned.
    The code is functioning, just lately I receive some report from colleagues of error and it turns out that it malfunctions only when called in layout editor session where there is no history of using/doing create contact command.
    best regards
    lrlsk
  • dmay
    The hiRegTimer will solve your problem. You said "it malfunctions only when called in layout editor session where there is no history of using/doing create contact command". The hiRegTimer can ensure the form is created before you access it. If you call leHiCreateContact to open the form, your skill will not continue to the commands that access the form until the form itself is canceled. If you only need it to exist, you can do this:
    unless(boundp('le0ContactForm)
      hiRegTimer("cancelEnterFun(le0ContactForm)" 1) leHiCreateContact()
    Derek
  • lrl12skdev
    Hi Derek,
     Thank you very much for your help. It works and it was really great. I never thought it would be as simple as that. Its really good we have this kind of forum.
    best regards,
    lrlsk
