  3. window coordinates
  • Views 15589
window coordinates
Danilo P
Danilo P over 15 years ago
I'm looking for a way to open schematic and layout windows in VLS-GXL mode at desired coordinates of the screen.
Is anybody aware of a way to do that?
  • skillUser
    skillUser over 15 years ago
    Hi Danilo,
    There are .cdsenv settings specific to VLS-XL which should apply to GXL too I think (I've not tested this, sorry):
    layoutXL schematicWindow string "((0  0) (0  0))"
    layoutXL layoutWindow string "((0  0) (0  0))"
    Try changing these settings to see if it helps. This can be done via SKILL also, for example:
    envSetVal("layoutXL" "schematicWindow" 'string "((0 0) (800 1000))")
    Hopefully this will help!
    Lawrence.
  • skillUser
    Hi Danilo,
    Sorry, there was a typo in the post which I've now fixed, the email shows the incorrect version, the post should show the correct values now in the envSetVal example.
    regards,
    Lawrence.
  • Danilo P
    Thank you Lawrence
    regards, Danilo
