  3. Any clue on the dbSave behavior change after dfII 6.1.*...
  • Replies 8
  • Views 18440
Any clue on the dbSave behavior change after dfII 6.1.* release?
Tongju
Tongju over 15 years ago
I have code like:
dbSave(cvid_org libName cellName viewName) ,
which works fine within dfII 5.1* release even when the target cell view (libName:cellName:viewName) is open for edit in the current session. Basically, it just overwrites the current target cellview with the contents in cvid_org.  As the result, I will see both disk and display window of the target cellview  are updated.
 However, in the dfII 6.1 release,  this same code  works correctly ONLY when the target cell is not open in the same session (memory) for edit. Otherwise, it complains "dbWriteCellView: Unable to lock database file for libName/cellName/viewName" and fails. Sounds to me that the same API will not be able to handle memory anymore: it couldn't figure out that the target cell is in memory in EDIT mode and it has the "lock" already.
 So, I am using a ugly work-around:  adding "dbPurge" first in my script to remove the target cell from memory and then, run the same dbSave, and reopen it after that.
Do you have any clue why its behavior should change to the new way? Do you have suggestion for better work-around?
 Tongju
  • Austin CAD Guy
    Austin CAD Guy over 15 years ago
     The OA database itself sets a "in use" flag when a cell is opened for edit. Virtuoso cannot override the flag.Try to change the mode on the cellView to read only (make it non editable, you may have to discard edits first) and then save the data.
     Ted
    Hi Ted,
    Unfortunately that doesn't work either - it says:
    *WARNING* (DB-270236): Cannot save to cellview 'amsPLL/blah/schematic'; the cellView is opened read-only.
    which is not very helpful. I think closing (purging) it is the only option at the moment (I tried "s" mode too (but that's really read in disguise)).
    Can't use dbCopyCellView, because it tells you:
    INFO (DB-170007): dbCopyCellView: amsPLL/blah/schematic already in VM. No copy being done.
  • Austin CAD Guy
    Thanks for correcting me, I do not have access to Virtuoso to test my suggestion.
    Sorry Ted - I guessed you'd not had the chance to try it. By coincidence I was looking into this at the same time as you, that was all.
  • Austin CAD Guy
    That's OK, I hate giving out bad info and welcome corrections.
    Ted
  • Tongju
    Hi, Ted and Andrew,
    Thank you for your information! After read your comments, I tried to dig out more from the Cadence OA documents. In the dbSave section, the document still tell me that I could save a cellview to a different open cellview as long as the target view is opened in "w" mode. Sounds the document about dbSave is not up-to-date yet. However, there is a release notes about dbCopyCellview and dbWriteCellView, which described the different behaviors of those commands between OA and CDB.  The description is very similar to what Ted pointed out: the operation is allowed when the target cell view is in "r" mode, but not in "a" or "w" mode. But actually, even opened in "r" mode for the target cell view, as Andrew said, you couldn't do the dbSave into the target cellview. Sounds there is a little bit confuse in the document.
     Tongju
    Please report this to customer support, and then we can get a CCR filed to get this fixed (I'd do it myself, but bit swamped at the moment).
  • Tongju
    Hi, Andrew,
     I have filed a SR (#42361144).  Also, I tried dbCopyCellView(cvid libName cellName viewName nil nil t), here, "t" means "allow overwrite", then, the dbCopyCellView works when the target cell view is opened in Virtuoso memory.  So, sounds the dbCopyCellView command is ok. But the dbSave command ONLY works when the target cellview is completely purged from memory.
     Tongju
