  3. Time delay between performance of functions
  • Views 7576
Slawa
Slawa over 15 years ago
Hi
 At me the following question: How to make a time delay between performance of two procedures (functions)? For example there is a first procedure proc1 (x=10 printf ("%d" x)) and the second procedure proc2 (x=x+10 printf ("%d" x)) How to make so that after the first procedure has transited N seconds before performance of the second?
In advance thanks
Slawa
    Hi Slawa,
    Your request is not that clear (to me). Are you trying to measure the relevant performance of the two functions (in which case you could use the SKILL profiler, although you'd have to call the functions often enough to get something significant)? Or are you trying to insert a delay between the calls (you could use sleep() for this)?
  • lrl12skdev
    lrl12skdev over 15 years ago
    Hi Slawa,
     I just recently ask similar question so I guess this is also applicable to you. you can use
    hiRegTimer("proc2" 1)  proc1()
    that means proc2 will be delayed by 1tenth of a second.
     best regards,
    lrlsk
  • Slawa
     Was specific in my task it is necessary to make switching of an icon of the button with a certain interval (blinking).
     For example at pushing the button, it for 1 second changes the color on green then returns a initial icon.
    That I want to receive that to me sees as follows:
    if("button push" then  putprop(curField myIcon2 '_buttonIcon) "DELAY(1 second)" putprop(curField myIcon1 '_buttonIcon))
     I hope now my question it is clear
    Slawa
    Hi Slawa,
    It would have been simpler if you asked the direct question initially! Anyway, hiRegTimer is the way to do this. The sleep() approach will block the UI.
    This solution 11381132 gives you a package around hiRegTimer which makes it easier to schedule repeating tasks, so you might find that useful.
    Andrew,
  • Slawa
    IrIsk and Andrew many thanks to you for the help. hiRegTimer it that is necessary.
    Best Regards,
    Slawa
