  3. How to compute the bounding box of a cell in a hierarchical...
  • Replies 13
  • Views 26912
How to compute the bounding box of a cell in a hierarchical design
Renee
Renee over 15 years ago
 I had some problems with the placing pad head in a chip design. In the orignal design, all IOs have been placed without pad head. As there are so many pads in the design, I tried to realize this function by writing a program.
 Here are the functions it should have:
1. It should be able to identity positions of each IO.
2. It should be able to place pad head to the relative positon.
Here are my general thoughts to realize these function:
1. As there are identify layers covering IO, thus in order to locate them, I could locate bounding box of those ID layers, then I can have the lowerleft and upperight vertexes of IO. (But I have problems with getting bounding box of a cell in a hierarchical design)
2. How to place cell at a specific position in a design automatically?
 Thanks in advance!
Lei
    Do a recursive descent of all the instances in the design, and look for the IO cells at each level. As you descend, you can keep track of the overall transformation (by looking at inst~>transform) and you can then concatenate all the transformations (using dbConcatTransform). You can then use this concatenated transformation to map any coordinates within the IO cell back to the top level cellView, and thus know where to place the "pad heads".
    There are quite a few examples of using recursion to visit all cellViews in a layout on http://support.cadence.com and similarly examples of using dbConcatTransform.
  • Renee
    My idea is this:
    It will go down from top level to bottom level automatically and check if there are IO cells at certain level.
    I used Andrew's code and modified it to realize the function:
    procedure(tra_v1(cellView levels transform)
    ; the variable levels is an indication of current level
      foreach(inst cellView~>instances
     if(inst>cellName=="VSSIO" then
           println("find it")
           println(levels)
           else println("haven't find it")
           );end if
      println(inst~>cellName)
      println(inst~>transform)
      tra_v1(inst~>master levels-1 dbConcatTransform(transform inst~>transform))
      ) ;end foreach
    procedure(hier_v1()
           cvId = deGetEditCellView()
           ident_transform = list(0:0 "R0" 1.0)
           levels = dbGetMaxHierDepth()
           tra_v1(cvId levels ident_transform)
    );end procedure
    But there are some problems with this program:
    • 1. It indeed prints some transform information of cells, but it terminates and reports that:
    Error: dbConcatTransform: invalid transform - nil
    • 2. I find that this program traverses only one cell from top level to bottom level which means that if there are instance I1 containing I2(containing I2_1) and I3(containing I3_1), it only reports transform information like this:
    I1 (0:0 "R0" 0)
    I2 (10:10 "R0" 0)
    I2_1 nil
    I would like that the program traverses both instance I2 and I3 from top to bottom level.
    Quick answer - the chances are that this is because you have mosaics in the design and are trying to look at the mosaicInst instances. You would need to filter out any instance with objType of "mosaicInst". Handling mosaics will get somewhat more complicated - so I'm hoping you don't have any mosaics of the cells you're trying to locate and so can safely ignore iterating over cvId~>mosaics in this case.
