  3. How to compute the bounding box of a cell in a hierarchical...
  • Replies 13
  • Subscribers 153
  • Views 27417
How to compute the bounding box of a cell in a hierarchical design
Renee
Renee over 15 years ago
 I had some problems with the placing pad head in a chip design. In the orignal design, all IOs have been placed without pad head. As there are so many pads in the design, I tried to realize this function by writing a program.
 Here are the functions it should have:
1. It should be able to identity positions of each IO.
2. It should be able to place pad head to the relative positon.
Here are my general thoughts to realize these function:
1. As there are identify layers covering IO, thus in order to locate them, I could locate bounding box of those ID layers, then I can have the lowerleft and upperight vertexes of IO. (But I have problems with getting bounding box of a cell in a hierarchical design)
2. How to place cell at a specific position in a design automatically?
 Thanks in advance!
Lei
  • lrl12skdev
    lrl12skdev over 15 years ago
    Hi Lei,
    Just to make a suggestion.
    for 1 I would rather get the IO  instance origin info (intsance->xy) and the transformation (intance->transform) instead of relying on a specified layer bounding box.
    then as you walk through all the IO instances, just simply instantiate the pad head instance, using the info on number 1 you should be able to calculate and placed them correctly relevant to the IOs.
    best regards -lrlsk
  • Renee
    Thank you for your reply!
    But I still had some questions with your suggestion:
    I tried to get the instace attributes with programs shown as below:
    cvId = dbOpenCellViewByType(libname cellname "layout")
    foreach(inst cvId~>instances
    println(inst~>bBox)
    I could only find bBox of instance, but not instance origin and transform(I don't know what the function of transform is).
    Meanwhile, if I instantiate mosaic instances in the cellview, I could not get each bBox of them. Then how could I get the information to calculate each IO's position.
    Lei
    Hi Lei,
    For an instance, you can use inst~>xy (to get origin) and inst~>orient (to get the orientation) or inst~>transform to get both together (along with a magnification - don't use this, since it's obsolete in OA). This is clearly covered in the documentation on database objects, and can be found by looking at inst~>??
    Mosaics are a little complex, but you find mosaics by looking at cvId~>mosaics (which has a bBox). An example of dealing with mosaics can be found in Solution 11328674
  • Renee
    I have limited access to cadence online support right now. Is it possible that you send me the solution through email(reneezl26@hotmail.com)?
    Thank you so much!
    Lei
  • Renee
    I have limited access to cadence online support right now. Could you send the solution to me through my email (reneezl26@hotmail.com)?
     Thank you very much!
    Lei
  • Austin CAD Guy
    Austin CAD Guy over 15 years ago
     Rather than going through all the instances in your design,sort through the instance headers to find the cells that match yourIO cells. The instHeaders have a pointer to the instances made by those masters. You will be processing much fewer objects. For regular cells there is one instHeader for each master, for pcells there is one instHeader for the superMaster and one for each variant.
     cvId = deGetEditCellView()
    listOfIOCells = list( "IO_cell_1" "IO_cell_2"...)
    ihList = setof( ih cvId~>instHeaders   member( ih~>cellName listOfIOCells ) )
    foreach( ih ihList
      foreach( inst ih~>instances
    ;; Process instances here
  • lrl12skdev
     Hi Renee,
     I totally agree to Austin and about your question on what's the importance of getting the IO origin and transform, here is my idea behind that, First I would measure the displacement from the IO->xy to the Pad origin (where you want it to be placed) the IO-orient will give you the idea whether it is rotated, mirroredX or mirroredY etc. So for each instance of IO you will know how to add this relative displacement when placing the Pad head. Of course if you have several flavors of IO instances then you just need to build each case in your code.
    For mosaic, it is the same story, you can olso get the mosaic number of rows or columns and the origin where the master is located.
    BR  lrlsk
  • Renee
    Thanks!I took your advice and realize those functions, but I still want to optimize my program and here are my thoughts:As shown in the below schematic, IOs are placed on four sides of the chip. I wrote a case function to detect the orientation of each IO (R0, R90, R180, and R270), then calculate the displacement of each pad head (the red rectangle).
    I don’t know if there are better solutions than case function, since I have to use it twice to get the finally coordinates of pad head. The first time, I need to find the center point of IO and the second time I need to transform the center point of pad head according to the center point of IO.
  • lrl12skdev
    Hi Renee,
     Sorry because I couldnt see your picture, but I think this is how you should do it
    1 you get the relative displacement (x and y) of the instance origin of the IO to the origin of the Pad Head
    then for each IO instance get the tranformation and mirroring and assign the same property for their own Pad head so you would only worry about the rotation.
    for Example at R0 the displacement is X and Y
    then at R90 x becomes y and y becomes -x, at R180 x becomes -x and y becomes -y lastly at R270 x bexomes -y and y becomes x
    you cancelled the effects of mirroring like for example R0MX because you have assigned same mirroring for the Pad Head.
  • Renee
    Thanks for your advice.
     I still have some problems with this pad head problem:
    If the IO instances are placed at lower level of the design and I could only add pad heads at the top level. How can I go through all the instances from top to bottom view and find these IO cell instance?
     Thanks!
