  3. Create custom button in ADE for running specific simula...
  • Subscribers 153
  • Views 16748
Create custom button in ADE for running specific simulation
tyanata
tyanata over 15 years ago
I have to create SKILL script which creates custom button in ADE.
The functionality of this button must be equal as "Run simualtion " button without netlisting.
Only one specific Environment option must be included: +query=tokenlic.
When includingthis this option simulation actually stops after netlisting (if there is netlisting) and in the output log is reported the number of token licenses.
My task goes further. I want the number of token licenses to be outputed on message window.
First hard subtask in this script is how to create custom button in ADE.
The second hard subtask is to run the simulation with +query=tokenlic.
Please give ideas about the realization of this script!
Best regards,
tyanata
  • berndf
    berndf over 15 years ago
    I think creating a button is not possible.
    But you can customized the menu
    Copy the required menu file from
    <cds_inst_dir>/tools/dfII/etc/tools/menus
    to <work_dir>/menus
    and do some experiments.
  • imagesensor123
    imagesensor123 over 15 years ago
        if you really (have to) build a button in ADE, I recommand you  create a form with specific button or customerize you own menus.
    zfeng
  • tyanata
     Yes,
    I  started to create custom menu in ADE. I found these topics on support.cadence.com:
    Solution ID: 11346956
    Solution ID: 11286092
    So I will try them.
    Best regards,
    tyanata
  • imagesensor123
       I also do some work under candence, and i am using skill to bulid some function in ADE, if you succeed in adding your custom menus , could you share the example(solution ID 11346956) with me, because our engineer is updating the cadence, i can view the online support solution now!
    thanks,
    zfeng
  • tyanata
    I apready succeeded to do the job written in the listed solutions.
    The specific thing is that you have to insert following line in your .cdsinit file:
    load("project_path/menus/spectre.menus")
    The bad thing is that this solution creates submenu My Options under menu Simulation->Options
    I Actually prefer the created new menu item to be on the top of ADE window, but as beginning of the task, it is already one step further..
    tyanata
  • imagesensor123
       it's really a good news, thanks for remending! you can refer to the analog artist skill reference P42, there are some explainations. Try coping the existing menus and modify it, I hope this can help you get your idea.
    zfeng
