  3. PCell: select parameter from drop-down?
  • Views 16328
StefanSL
StefanSL over 15 years ago
 Dear all,
for a pCell, i need to implement the possibility to make layer and purpose accessible
as parameters;
currently i've defined two parameters, the user has to fill in the name of the layer;
this is a bit tedious and the user needs to know the exact name of the layer, it's often
more than just 2 characters.
Is there a way to implement a drop-down-list that shows a set of layers (or lpps) to select
from (like in the attribute-panel for shapes)?
thanks for your help
Stefan
  • Danilo P
    Danilo P over 15 years ago
    Hi Stefan,
    the field you need can be created by the command hiCreateLayerCyclicField.
    Regards, Danilo
  • StefanSL
     Hi Danilo,
    thanks for your fast response;
    are you sure this field can be used within a pCell?
    Could you please give me some hints how to accomplish this?
    Another approach might be to implement my own form to
    make all parameters accessible
    (from thispcellinst~>?? and thispcellinst~>master~>parameters~>prop)
    but i didn't want to re-invent the wheel, so if there's a built-in function...
    kind regards
    Stefan
    Hi Stefan,
    I was about to reply in response to Danilo's post, because you can't really do that, since there's no "LPP" type in CDF, which is what you'd need so that CDF-based forms could construct using an LPP field.
    So the only alternatives are to either have a type-in field, or to implement your own form for changing the properties of your pcell.
  • StefanSL
    thanks for your confirmation;
    so i'll build a form on my own, similar to leHiEditProp(), that allows
    selecting the desired lpp in a more convenient way;
    to maintain the standard behaviour, i could redirect the "q"-bindkey to
    a function that checks if the selected item is a certain type of pcell
    and then either hands over the request to my new form or to the standard
    leHiEditProp() .
    best regards
    Stefan
