  3. How to measure time which Virtuoso takes while acquiring...
  • Views 15876
How to measure time which Virtuoso takes while acquiring license?
Ilya Temnikov
Ilya Temnikov over 15 years ago
 Hello. Is it possible to measure time which Virtuoso takes while acquiring license during loading? If yes then what actions I should do?
    If using IC614 or IC615 (also later IC613 hotfixes), there are a whole bunch of environment variables which enables this. Search in cdnshelp for "Setting License Check Environment Variables"  (include the quotes) and you'll find the details.
  • skillUser
    skillUser over 15 years ago
     Hi Ilya,
    In addition to what Andrew mentioned, in the IC614 release and later (and some later IC613 ISRs) there is a utility called perf_test which is not within virtuoso but it is in the IC installation.  This utility can be used for measuring license access time and testing the licensing environment to help diagnose any issues.
    Hope this is helpful information.
    Lawrence.
