  3. Getting inherited connection property value from the top...
  • Subscribers 152
  • Views 14959
Getting inherited connection property value from the top of hierarchy
Ilya Temnikov
Ilya Temnikov over 15 years ago
 Hello. How is it possible to get inherited connection property value from the top of hierarchy from child instance cellview if I used "Descend" into schematic instances down to some level. So I want to know an information about parent instance from this level.
  • markbeck
    markbeck over 15 years ago
    One method to get to the top of hierarchy, is the topCellView property of the window
    e.g.
    w_current = hiGetCurrentWindow()
    d_top = w_current->topCellView
    This will return the top cell view's object, from there you should be able to figure out top level circuit properties.
    Does this help?
  • Slayer
    Slayer over 15 years ago
     Try to use the dbGetAnyInstSwitchMaster function. Yoy make loop for all instances on top level and appply this function to get all subInstnces in that instances descent until find masterneed master&
