  3. editable condition of CDF parameters (for Layout Pcells...
  • Replies 7
  • Views 19293
editable condition of CDF parameters (for Layout Pcells)
djeto38
djeto38 over 15 years ago
Hi All ,
I would like to insert editable condition on CDF parameter of Layout Pcells but i don't know the exact syntax and procedure to call .
Has someone an idea about this mistake ?
Thanks in advance .
djeto38
    Hi djeto38
    What is the condition you want? It's just a SKILL expression, but hard to advise without knowing how you want to determine whether the field is editable or not.
  • djeto38
    Thanks for your answer .
    I have several Arguments (parameters) in my Layout Pcell .
    Mos_Type  string "mos" (or "mos_hvt")
    Mos_Length float 1.0
    Mos_Width   12.0
    etc .........
    And I would like to make Not Editable Mos_Length when Mos_Type == "mos_hvt" fro example .
    So I search for CDF syntax .
    Best Regards ,
    Djeto38
    cdfgData->Mos_Type->value!="mos_hvt"
    Would be the expression in the editable field for the Mos_Length param in the CDF.
  • djeto38
    Many Thanks for your quick answer .
    Jérome
  • djeto38
    It 's OK for one argument , but how can i do to read a Argument list instead . (cdfgData->Mos_Type->value!=list("mos_hvt"  ||  "mos_hvt_ver2"  ||  "mos_hvt_ver3" )
    Regards ,
    Jérome
    Jerome,
    !member(cdfgData->Mos_Type->value list("mos_hvt"  "mos_hvt_ver2"  "mos_hvt_ver3" ))
    Is one way. Essentially it's a SKILL expression, so worth making you understand the basics of SKILL. Provided you know about cdfgData->paramName->value you can use any SKILL conditional statement.
    Look in the SKILL Language User Guide for more details on the language.
    Best Regards,
  • djeto38
    Thanks again Andrew
    Best Regards
    Jerome
