  3. tooltips for CDF fields
  • Views 15067
Adrian Nistor
Adrian Nistor over 15 years ago
Is there any possibility to add tool tips to the CDF fields?
my purpuse would be (for example) : the user opens the properties of a layout parameterised cell, selects parameters tab; when <mouseOver> any existing field, a tool tip appears and give to the user more detailed information regarding the specific field;
Thank you.
    Form fields in IC61 can have tool tips, but it would need CDF to allow you to define the tooltip info, and for all the CDF-based forms and assistants to be able to pick this info up and use it. This is not possible now as far as I know, but it seems a reasonable enhancement request.
    Nistor, can you log this as a service request, and then one of the team can file a CCR (I'd do it myself, but I don't have access today).
  • Adrian Nistor
    Thanks for your fast reply; I did what you recommended to do:
    Tooltips for CDF fields
    42372472
    Best Regards
