  3. can we create a table or form to display my data in memory...
  • Replies 10
  • Views 7104
can we create a table or form to display my data in memory, looks like "excel" shows?
imagesensor123
imagesensor123 over 15 years ago
 Hi everyone,
     do you need to display your memory in a table or a form, or is it other way to display my data store in memory, i want to show the data to my customer, can you give me some advice, welcome to discussing about this.
zfeng
  • Quek
    Quek over 15 years ago
    Hi zfeng
    I think you would have to let us know in more details the specific data which you are refering to. E.g. viva waveform data? layout data? schematic nets?. Please also provide the version of Virtuoso which you are using.
    terminal>virtuoso -W
    Best regards
    Quek
  • imagesensor123
     Hi Quek,
        thanks for replying, my problem is that, i have a matrix[100][100] (the reslut of a equation stored in memory, float numeric data,eg 0.5689) , i can cite each one by matrix[i][j],as far as i know, we can display a signal like a table( time and value), so i think my idea is reasonable.I use ic5141.
  • Quek
    Hi zfeng
    How about displaying the data in a text file? You can indeed display the data in a table inside a form but it would take slightly more coding. Using a text file seems to be the simpler approach. You can perhaps do more modifications for multi-column output to make things look nicer. : )  Hope that this is useful for you.
    outPort=outfile("/tmp/matrix.txt")
    for( i 0 100
       for( j 0 100
          fprintf(outPort "matrix[%n][%n] : %g" i j matrix[i][j])
       ) ;for
    ) ;for
    close(outPort)
    view("/tmp/matrix.txt")
    Best regards
    Quek
  • imagesensor123
    Hi Quek,
       thanks for your advice, this is a good idea for common usage but i intend to attache a table(like you said) in my form so that i can check the result easily. do you know which is a mainly function in skill to create a table and append it in my form?
    zfeng
    How about hiCreateReportField() or maybe hiCreateTreeTable(). More details in the documentation.
  • imagesensor123
         I have thought out  a method, firstly,we can create a multiple text field and then attach it in your own form , use a function to read out the data( i have printed the data in memory to the fle), convert all the data ( read out) into a string ,and then pass this string to the multipleTextField. it's a little complicate!
    refer to: hiCreateMLTextField
                hiCreateAppForm
    there is an example in the skill user interface function reference P521
    zfeng
  • Quek
    Hi zfeng
    Please refer to solution 11457458 for an example on hiCreateReportField.
    Best regards
    Quek
  • imagesensor123
    Hi Quek,
        Thanks!
    zfeng
  • zmleitao
    zmleitao over 12 years ago
     Do you know how to create a similar table as in the ReportField, but with one or more editable entries on each row?
    I would like to create a table with some ComboFields as entries, as in the "Copy Cell"->"Copy Problems" Menu of Cadence Virtuoso, where such a table enables the user to select if he wants to overwrite the conflicted files or not.
    Please read the forum guidelines - you've not only posted on the end of an old thread, but also separately asked the same question in a separate post.
    See my answer to your other post.
