  3. How to automatically update all other layers if I change...
  • Subscribers 150
  • Views 15787
How to automatically update all other layers if I change a Gate width in Standard Cell
ttran0671
ttran0671 over 15 years ago
 Dear Experts,
    I'm currently having a problem. I'm new in Virtuoso and I'd need your help.
I currently have an existing Standard Cell Layout Library and I'd like to change the Poly
Gate Width of Pull-Down NMOS from 0.5 to 0.6 and I'd like to know if there are way in
Virtuoso Layout to automatically changing all other layers to fix DRC automatically.
Alan
    Alan,
    I split this from the thread it was attached to (not sure how it got attached to the thread it was on).
    The best way to do this is probably with the Virtuoso Layout Migrate tool (or maybe a search and replace and then a Virtuoso Layout Optimize). More in the documentation... This is essentially a compression technology approach (it may need to decompress it in this case as a dimension has got larger).
  • ttran0671
     Hi Andrew
       Yoeu're the man. Thanks for enlightment me. Could you give me more details how to do it?
    To be honest, I think you really help los of people that post in this forum and please keep up the good work. If you have a details doc or some sort of instruction that you could send me, that'd be great.
    Thanks A million
    Alan
    Hi Alan,
    I suggest you start by looking at <ICinstDir>/doc/migrate/migrate.pdf . For additional help, probably worth contacting Cadence Customer Support (VLM is a fairly niche product).
    Best Regards,
