  3. leIsPointInsideFig Bug?
  • Views 14944
Adrian Nistor
Adrian Nistor over 15 years ago
I have a specific strange situation, and I do not know how to handle it. I'm using Virtuoso 6.1.4.To replicate this you can do the following in for new layout cell view:
in CIW:
 pts = list(
    list(0.0 19.2)
    list(0.0 0.0)
    list(53.25 0.0)
    list(53.25 97.7)
    list(39.25 97.7)
obj = dbCreatePolygon(cv() "poly" pts) ;; Create a polygon
bx = list(list(17.4 19.2)
    list(21.2 23.45)
r = dbCreateRect(cv() "metal1" bx) ;; Create a small rect, this is only for visual help
lowerLeftPt = lowerLeft(r~>bBox) ;; Take the lower left point of the polygon
leIsPointInsideFig(obj lowerLeftPt) ;; ~> this will return nil !! WHY ?
No move the small rect "one grid" in top or bottom direction and retry the leIsPointInsideFi, it will return t.
Only on that horizontal line the problem appears.
Is this a bug?
Thank you,
Best Regards,
Adrian
    Hi Adrian,
    This looks like  a bug to me. Please file a service request. It seems to be an issue if the shape is concident with a line drawn from one of the vertices. I believe it uses some kind of scan line approach, and something is probably wrong in the code.
    As a workaround, you could use the SKILL code in Solution 11024326 . In this there is CCSpointInPolygon, and you could use CCSpointInPolygon(lowerLeftPt obj~>points) (strictly you should check using CCSpointOnBoundary() too  - see comments in the code).
