  3. cant pass the parameters to a pcell ?
  • Views 15526
Mohellayali82
Mohellayali82 over 15 years ago
dear all,
i have an issue with a skill code, i am newbie actually, so the example is simple
pcDefinePCell(
        list(ddGetObj("test_pcell") "first_example" "layout")
                (www 3.0)
        let(
                ((cv pcCellView))
                cellId = dbOpenCellViewByType( "cmos065_rf" "plvtlp_rf" "layout")
                inst = dbCreateParamInst(
                        cv cellId nil list(1 1) "R0" 1
                        list(
                                list( "w" "float" 3.0)
                                list( "nfing" "integer" 4)
        ); let
so in my pcell first_example, i instanciate another pcell (plvtlp_rf), and i hard coded (for now) the 2 parameters that i pass to it w and nfing
but when i instanciate the master pcell (first_example) , the values are not passed to the sub pcell, and i have instead the default values of this cell.
what is strange is when i descend into hierarchy , and i do q in the subcell, in the edit properties i see that the parameters of the pcell are those that i passed w=3 , nfing =4 , but visually they dont appear
can somebody help me please by telling me what i did wrong
  • Mohellayali82
    just one precision
    the sub-pcell is a pcell from the foundry DK, when instead of using this one , i instanciate a pcell of mine it works but when i instanciate the pcell "plvtlp_rf" it no more work,
    A couple of possible problems - you've either given the wrong parameter names, or the wrong type. Look at the pcell parameters by doing:
    cv=dbOpenCellViewByType("pdkLibName" "plvtlp_rf" "layout)
    cv~>parameters~>value~>name
    cv~>parameters~>value~>valueType
    The last two lines will list the parameter names and types, in the same order. So you can match them one for one.
  • Mohellayali82
    Thanks a lot Andrew, it works now
    the problem was a wrong type as you pointed out, "nfing" and "w" were both strings
    Best regards
