  3. execute diva command "directly" in skill ? possible?
  • Views 2568
Peter123
Peter123 over 15 years ago
I can execute diva rules file in skill by using ivDRC..
May i know any alternative way to execute DIVA command in skill "directly" without using ivDRC?
Understand that, DIVA and skill are 2 diff platform...Just curious to know...
-P-
    You can't. You launch Diva DRC with the ivDRC() SKILL function. The fact that Diva rules have SKILL syntax and are embedded in a call drcExtractRules() is neither here nor there - that's just the definition of the rules. To run them, you need to use ivDRC() which allows you to specify the cellView being verified, and so on.
  • Peter123
     noted...
    Thanks for you quick response..
    -p-
