  3. Get hierarchical net name of one terminal on all instances...
  • Views 18383
Get hierarchical net name of one terminal on all instances of a particular cell
jorankin
jorankin over 15 years ago
I am using Cadence IC6.1.4.500.5.
I have been tasked with the following:
1. Find all instances of a cell called, for example, "switch."
2. On each instantiation of "switch," do the following:
      a. find the terminal in<1>, measure the voltage on the net connected to that terminal
      b. save the net name (the hierarchical net name, not the name on that particular schematic ) of the net that is connected to that terminal in (a) above.
   I have tried to figure this out using the documentation for days, but I just can't seem to get anywhere. The following is what I've tried:
1. Use the schHiFind() function (and related settings) to select the cell. Then get information about the terminals to hopefully get the net information. The problem with this is that I can't seem to extract the net name the way that the calculator does. This is what I do:
_hiFormApplyCB(schSchFindForm) ; assuming form is setup correctly, tell the form to press ok
schFindSelectObject()   ;select the object as well as find it  geEnterAddInstProbe(hiGetCurrentWindow() )     ;probe the cell
OBJECT=geGetAllProbe(hiGetCurrentWindow())~>pathObjectName         ;tell me the instance of the probed cell
OBJECT=car(OBJECT)
PATH=geGetAllProbe(hiGetCurrentWindow())~>pathList              ;tell me the path to the probed cell
PATH=car(PATH)
NETS=css()~>terminals~>net~>name;    give me the net name of the nets connected to the cell I select
ONOFF=nth(2 NETS)
PROBES=nth(1 NETS)
VEX=strcat("/" PATH "/" OBJECT "/" ONOFF)
VEX2=strcat("/" PATH "/" OBJECT "/" PROBES)
VDC(VEX); get voltage of switch terminal
Unfortunately, this doesn't work because what appears in the calculator isn't always what I get above. For example, above I might get "/I0/I2/I26" for PATH and "I105" for OBJECT. For PROBES I might get something like net061. Then if I do VEX=strcat("/" PATH "/" OBJECT "/" ONOFF), I get "/I0/I2/I26/I105/net061". Then, If I do VDC(VEX), I get VDC("/I0/I2/I26/I105/net061"). The problem with this is that when I use the calculator and probe the specific net of this specific instance, I get VDC("/I0/I2/net061") because net061 appears at upper levels of hierarchy. So my VDC(VEX) expression doesn't work...
So what I am wondering is if there is a way to get the net name and path at the highest level of hierarchy that it appears. My thought is that if the calculator can do it, I should be able to find a way to do it...
Another issue I have is that I am using the probe function and schFind-related functions to do my work. This is not optimal. The only reason I am doing this is because it has gotten me the farthest. If I want to do the above routine without a schematic opened (i.e., as a procedure in an OCEAN script), I am guessing that I'll be out of luck. So is there a different way to do the above?
John
  • markbeck
    markbeck over 15 years ago
    I think what you're looking for is: geGetAdjustedPath() This will allow you to feed it a lower level name and it will search for the top-most level name that should be probe-able. Mark
  • jorankin
    Mark,
         Ok thanks. I was able to use this function with the following to have the hierarchical path returned as it would appear in the calclulator:
    geGetAdjustedPath(hiGetCurrentWindow() strcat(geGetInstHier() nth(5 css()~>terminals~>net~>name)))
       The above command will return the hierarchical net name (as it would come back in the calculator) of the 5th terminal on a cell that is selected within the hierarchy.  One would think that you could just concatenate geGetInstHier() with the net name within the level of hierarchy that you are selecting the cell in, but if the net you are interested in propagates to a higher level of hierarchy, this may not be the case depending on netSet information.
    John
