  3. asiWriteOceanScript save the ocean, but missing the "plot...
  • Views 1148
asiWriteOceanScript save the ocean, but missing the "plot"
imagesensor123
imagesensor123 over 15 years ago
   have you ever used the function "asiWriteOceanScript" , i got a strange script from the command,please look at the following lines
; ; Designer: zhenfu Date: 2011.1.1
ocnWaveformTool( 'wavescan )
simulator( 'spectre )
design(     "/home2/zfeng/Cadence/Techno035/Sim/zfgetpixelmodel/spectre/schematic/netlist/netlist")
resultsDir( "/home2/zfeng/Cadence/Techno035/Sim/zfgetpixelmodel/spectre/schematic" )
modelFile(
    '("/eda/Design_kits/AMS_3.70/spectre/c35/mcparams.scs" "")
    '("/eda/Design_kits/AMS_3.70/spectre/c35/cmos53.scs" "cmostm")
    '("/eda/Design_kits/AMS_3.70/spectre/c35/res.scs" "restm")
    '("/eda/Design_kits/AMS_3.70/spectre/c35/cap.scs" "captm")
    '("/eda/Design_kits/AMS_3.70/spectre/c35/bip.scs" "biptm")
    '("/eda/Design_kits/AMS_3.70/spectre/c35/ind.scs" "indtm")
analysis('tran ?stop "20u"  ?errpreset "conservative"  ?t "spectre.ic"
        ?t "spectre.fc"  ?t "status"  ?t "5"  ?t "0.0"
        ?t "node"  ?t "name"  )
desVar(      "cpix" 3e-09    )
desVar(      "lbias" 2e-06    )
desVar(      "lfollower" 2e-06    )
desVar(      "lin" 4.919e-08    )
desVar(      "lrst" 2e-06    )
desVar(      "lselect" 2e-06    )
desVar(      "pulseperiod" 1e-05    )
desVar(      "pulsewidth" 2e-06    )
desVar(      "vbias" 1.5    )
desVar(      "vread" 2    )
desVar(      "wbias" 4e-06    )
desVar(      "wfollower" 2e-05    )
desVar(      "wrst" 1e-05    )
desVar(      "wselect" 4e-06    )
desVar(      "delay" 2e-06    )
envOption(
    'pllPlugin  ""
    'skiPlugin  nil
    'firstRun  t
    'enableArclength  nil
    'recover  ""
    'checkpoint  ""
    'spp  ""
    'autoDisplay  t
    'userCmdLineOption  ""
    'analysisOrder  list("dc")
    'paramRangeCheckFile  "/eda/Design_kits/AMS_3.70/spectre/ams_range.lmts"
option(    'reltol  "100e-6"
    'vabstol  "1e-6"
    'iabstol  "1e-12"
    'temp  "27"
    'tnom  "27"
    'homotopy  "all"
    'limit  "delta"
    'scalem  "1.0"
    'scale  "1.0"
    'compatible  "spice2"
    'gmin  "1e-12"
    'rforce  "1"
    'maxnotes  "5"
    'maxwarns  "5"
    'digits  "5"
    'cols  "80"
    'pivrel  "1e-3"
    'ckptclock  "1800"
    'sensfile  "../psf/sens.output"
    'checklimitdest  "psf"
saveOption('save "allpub" )
saveOption( 'pwr "" )
saveOption( 'nestlvl "" )
saveOption( 'currents "" )
saveOption( 'subcktprobelvl "" )
saveOption( 'useprobes "" )
saveOption( ?saveahdlvars "" )
saveOption( ?modelParamInfo t )
saveOption( ?elementInfo nil )
saveOption( ?outputParamInfo nil )
temp( 27 )
run()
zfSignalPostProcess
 the above script is generated by asiWriteOceanScript
run()
selectResult( 'tran )
plot(getData("/Vout") getData("/net20") getData("/net28") getData("/net26") )
zfSignalPostProcess
but when i use the session->save script, i get a different output like the above four lines , does anyone know why the command asiWriteOceanScript  make the script without selectResult and plot?
zfeng
  • imagesensor123
       Actually, the first script looks more like a common script,  the biggest problem is that the first time i can get the right script(by user function asiWriteOceanScript), but after i load it and  regenerate the script again(by user function asiWriteOceanScript ) , i get the script lossing the plot and selectResult.
     procedure(zfSaveOcean()
    ;;imagerSevSession=sevSession(hiGetCurrentWindow())
    CurrentSession=asiGetCurrentSession()
    ;sevSaveOceanScript(imagerSevSession)
    ;sevRunEngine(imagerSevSession)
    ;success = asiCheckSimulationSuccess( imagerSevSession )
    ;;zfOceanPath=imagerForm->saveOcean->value
    ;;saveDefaultsFlag=envGetVal("asimenv.misc" "saveDefaultsToOCEAN" )
    fp=asiOpenOceanScript(imageOcnFile)
    zfPreSaveOceanScript(CurrentSession fp)
    asiWriteOceanScript( fp CurrentSession ?noRun nil ?fullKey t)
    zfPostSaveOceanScript(CurrentSession fp)
    asiCloseOceanScript(fp)
    i found that "CurrentSession=asiGetCurrentSession()" get the same return value, but you will get different return value if you load a script between the two times CurrentSession=asiGetCurrentSession(), like this
    load(script from the CurrentSession)
    i want to re-run a design with different designVarValue in ADE, so i generate a script everytime after changing the design varibale value by user function, and load it automatically . so it looks like the paramAnalysis, but a little different.
