  3. getAsciiWave
  • Views 17476
getAsciiWave
imagesensor123
imagesensor123 over 15 years ago
  there is a function named "getAsciiWave()", it's really useful for printing some data as a curve,but i found two arguments which are x_skip y_skip in the function, it seems that we can just skip lines from the begining of the file, so problem is that if we can pick up some lines in a file to be printed, such as we just need to print the lines from 20 to 40 as a curve, i think this function is not applicable for this requirement, do you have a better way? thanks in advance!
addition: getAsciiWave() is in the oceanref P201
zfeng
    Zfeng,
    You should be able to adapt this code to meet your requirements:
    Note: a newer version (June 2020) has been added in this post which allows the maximum number of rows to be read to be specified.
    /* abTable.il
    Author A.D.Beckett
    Group Custom IC (UK), Cadence Design Systems Ltd.
    Language SKILL
    Date Jan 11, 1999
    Modified
    By
    Read a waveform from a file of numbers, and return
    it as a waveform object
    e.g.
    myWave=abTable("data.asc")
    myWave2=abTable("withheader.asc" ?skip 1 ?xCol 2 ?yCol 3)
    SCCS Info: @(#) abTable.il 01/11/99.13:03:34 1.1
    * (abTable fileName @key (xCol 1) (yCol 2) (skip 0)) *
    * Reads a tabulated file of numbers from file specified in *
    * fileName, and the remain arguments are keyword. xCol and yCol *
    * are the column numbers of the x and y axis (starting from 1). *
    * skip is the number of lines to skip at the beginning (for headers). *
    * A waveform object is returned. *
    (procedure (abTable fileName @key (xCol 1) (yCol 2) (skip 0))
    (let (prt line wave xVec yVec xVal yVal)
    (unless
    (setq prt (infile fileName))
    (error "Could not read waveform from file %s\n" fileName)
    /* skip header lines */
    (for count 1 skip
    (gets line prt))
    /* create the empty vectors */
    (setq xVec (drCreateVec 'double 1))
    (setq yVec (drCreateVec 'double 1))
    /* these want to be zero indexed */
    (postdecrement xCol)
    (postdecrement yCol)
    (while (setq line (lineread prt))
    /* ignore blank lines */
    (unless (equal line t)
    (setq xVal (nth xCol line))
    (setq yVal (nth yCol line))
    (unless (and (numberp xVal) (numberp yVal))
    (error "Invalid data %L\n" line)
    (drAddElem xVec xVal)
    (drAddElem yVec yVal)
    /* create the waveform object and return it */
    (setq wave (drCreateEmptyWaveform))
    (drPutWaveformXVec wave xVec)
    (drPutWaveformYVec wave yVec)
    wave
  • imagesensor123
         i will try it as soon as possible, thanks very much!
    zfeng
  • imagesensor123
       i changed it a little, it works very well , thanks
    Best regards,
    zfeng
