  3. Remove /* this is a comment line */ from a file
  • Subscribers 150
  • Views 22358
Charley Chen
Charley Chen over 15 years ago
Dear All,
I wnat to remove a file which each line has  /*  a bc  d */  .
I use infile & outfile command.
How to do it ?
Thank you,
Charley
  • Charley Chen
    /*  ..... */  is a comment , don't care what inside the /*  */.
    Just need to check whether has a /*   */ in each ine.
    Thank you,
    Charley
  • skillUser
    skillUser over 15 years ago
     Hi Charley,
    More details in the question might lead to a better answer, and maybe even a correct answer.  I'm just guessing here.
    This might not be the best approach, but here's a possible example:
    fp = infile("somefile")
      => port:"somefile"
    gets(line fp)
      => "/* this is a comment, ignore */"
    rexMatchp("/*[^*/]**/" line)
      => t   so ignore that line
    gets(line2 fp)
      => "thisShouldBeSKILL='syntax"
    rexMatchp("/*[^*/]**/" line2)
      => nil   do not ignore this line
    If using IC61x there are Perl compatible regular expression functions starting with the prefix pcre - these give the full capability of regular expressions and may be easier to work with than the "rex" prefix functions.
    Anyway, I hope this helps?
    Lawrence.
  • Charley Chen
    Hi Lawrence,
     I works. That's what I need.
    Could you explain why the pattern should be "/*[^*/]**/" ?
    Thank you very much,
    Charley
    Hi Charley,
    It's an attempt to limit the fact that wildcards match as much as possible - so if you had /* something */ */ the pattern will match up to the first */ . If your pattern was "/\\**\\*/" then it would match up to the second */ (which is not the extent of the comment).
    Note I escaped the * which are part of the comment - can't see Lawrence's post right now, but in the pattern you reference below that hasn't been done, so it would also match "/////blah blah /" which isn't right. It also wouldn't match "/* test * comment */" or "/* test./ comment */" because the [^*/] bit will prevent it matching either of the / or * characters within the comment. It also won't match multi-line comments.
    This could almost certainly be handled with the more advanced pattern matching available in the pcre functions, but if you're merely looking for the presence of a comment, it is probably sufficient to just search for "/\\*" - i.e. the start of the comment.
  • Charley Chen
    Thank you for explanation . It's very helpful.
    Charley
  • mbracht
    mbracht over 8 years ago in reply to Andrew Beckett
    Andrew, pcreCompile() takes an optional second argument to define all kinds of options - those options in turn need to be generated with pcreGenCompileOptBits(..)
    So to turn on non-greedy matching you need to go like that:
    (pcreCompile <whatever pattern> (pcreGenCompileOptBits ?ungreedy t))
    Max
