  3. How to change subRect contact size by ROD ?
  • Subscribers 152
  • Views 17473
Charley Chen
Charley Chen over 15 years ago
Dear All,
 I use rod to create a guardring path , original cont size is 0.3x0.3 in subRect ,
how to change it from 0.3x0.3 to 0.28x0.28 ?
Thank you,
Charley
  • Quek
    Quek over 15 years ago
    Hi Charley
    In IC615, MPP subparts can be access through new SKILL APIs such as rodGetSubPart, rodAddSubPart and rodDeleteSubPart. I think you should be able to resolve the problem using these functions. Please refer to $CDSHOME/doc/roduser/roduser.pdf for more info.
    Best regards
    Quek
  • Charley Chen
    Hi Quek,
    I am using IC 5.1.41 , what command can I use to do ?
    Thank you,
    Charley
  • Quek
    Hi Charley
    Actually prior to the addition of the 3 SKILL APIs, an MPP was treated as a single unit and hence there is no way to manipulate the subparts using SKILL. It might be possible to workaround this by manipulating the subpart form but I have not tried it. Luckily this is a SKILL form (as opposed to a C form for layout objects properties) so I think much can be done with it. Maybe you can give it a try.
    Best regards
    Quek
    The supported way in IC5141 is to do a rodUnNameShape and then you can manipulate the subparts (but it's no longer a ROD object, of course).
  • Charley Chen
    Hi Quek,
    Thank you , I will try it.
    Charley
  • Charley Chen
    Thank you for help. I will try it.
    Charley
