  3. How to change Dimensions of cells using SKILL
  • Views 15669
bappada
bappada over 15 years ago
In 45nm technology , the default dimensions are in microns whereas in 28 nm the unit u has to be mentioned ( default is metre (!)) . While writing a skill script to port schematics from 45 to 28 , how should I take care of the dimension conversion automatically?
    Multiply the dimensions by 1e-6?
  • bappada
     I use the following to change the dimensions ( to accomodate for the default micrometre)  but no change is seen.
    oldW=dbGetq(inst w)
    if( rexMatchp("[nu]"||"e-6" oldW)
    then
    dbSetq(newInst oldW w)
    else
    dbSetq(newInst strcat(oldW "u") w)
    Probably the parameter is either not called "w" - maybe that is not the displayed parameter on the form? Hard to tell without seeing the data.
