  3. how to get orientation of a cell ?
  • Replies 7
  • Views 18088
bappada
bappada over 15 years ago
how do I access  orientation of a cell ?  inst~>orient is not working.
    inst~>orient should work fine, assuming that the variable inst is actually containing an instance Id. What does inst~>objType return? You say it "is not working" - what do you mean by "not working"? What does it return?
  • bappada
    I returns nothing . while printing it [printf ( " %s "  inst~>orient )] it shows that the argument to printf is nil . inst does contain an instance id.
  • bappada
    BTW, inst contains layout view.
    Make it print inst~>objType please... what does that say?
  • bappada
    It says "mosaic" whereas the orientation is "R0"
    So in that case, it isn't an instance id, it's a mosaic id. You can see the orientation looking at mosaicId~>tileArray (assuming it's a simple mosaic, which is all that's possible in IC61, then car(mosaicId~>tileArray) will tell you.
  • bappada
    Thanks a lot for the info.
