  3. how to change "[@cellname]" label height and labelJustify...
  • Views 3754
how to change "[@cellname]" label height and labelJustify ??
yuhua
yuhua over 15 years ago
Dear all ,
 i want to change symbol label "[@cellname]" by skill code.
but i don't know how to change height and labelJustify value by skill ?
the code is not work .
pls help it , thanks
; skill code start
procedure(SymbolCellName(libName)
let((cv libId label0)
libId=ddGetObj(libName)
foreach(cell libId~>cells
if(member("symbol" cell~>views~>name)  then
cv=dbOpenCellViewByType(libId~>name cell~>name "symbol" "" "a")
label0=if(member("[@cellName]" cv~>shapes~>theLabel) then
label0~>labelJustify~>value = "lowerLeft"
label0~>lHeight~>value = 0.1
printf("Done - cell \"%s\" \n" cv~>cellName)
dbSave(cv)
dbClose(cv)
;skill code end
  • skillUser
    skillUser over 15 years ago
     Hi Yuhua,
    Your code seems close, I think you only need to modify the "if" statement:
    when(label0=car(setof(label cv~>shapes label~>theLabel=="[@cellName]"))
    ); end when
    Please note that I have not tested this, I am just reading the code.  I changed the use of "member" to "setof" to obtain the label dbId.  I also changed the "if" statement to "when" since it does not have an "else" part.  Hopefully this will fix the problem though.
    Best regards,
    Lawrence.
  • yuhua
    Hi Lawrence ,
     thanks for your help .
    i still could not change height ad justification.
    the original code "if" statement is work
    i try the statement to change label setting by skill code
    label0~>labelType="ILLabel"              ----------------> is ok , the type will be change
    label0~>labelJustify="lowerLeft"         ----------------> not change , none error message
    label0~>labelHeight=0.1                   -----------------> not change , none error message
    i still could not change label height and justification by skill code.
    BRs
    YuHua
    Hi YuHua,
    It should be:
    label0~>justify="lowerLeft"
    label0~>height="0.1"
    You got the attribute names wrong. If you do label0~>?? you'll see the names and values of all the attributes on the label object (it's in the documentation too for the database objects).
  • yuhua
    Hi andrew ,
     it's ok work now .
     label0~>??  --> This is a good way to check, thanks for your great help
    BRs,
    YuHua
