  3. running multiple ocean simulations from a single host
  • Subscribers 150
  • Views 16882
Wonyoung
Wonyoung over 15 years ago
I had problems running multiple ocean simulations from a single host under IC5.1.4. Several of the simulations would crash, but the problem was solved by running only 1 ocean simulation per host. (related post: www.cadence.com/.../18294.aspx).
I tried this with IC6 to see if that changes anything. We have a variety of hosts with 4-12 cores each, and I ran 1 ocean simulation per core (4-12 simulations per host). I used the same command "ocean -log CDS.log.mylogfile -nograph -restore myoceanfile.ocn", and used different log file and .ocn file names across simulations. The ocean simulations crashed again, but with a slightly different message (attached below). Again, the problem didn't appear when I ran only 1 simulation per host.
Could anyone help me solve this problem and let me run multiple ocean simulations per host? It just doesn't seem right that I can run only 1 ocean simulation per host when there's a ton of multi-core hosts out there.
Thank you very much.
X connection to vasuki.eecs.harvard.edu:80.0 host broken (explicit kill or server shutdown)
\e IO Error 32 (Broken pipe) on Display "vasuki.eecs.harvard.edu:80.0"
\e Aborting due to fatal X IO error.
\o INFO (DB-170018): (dbPanic) dumping stack
\o virtuoso:dbPanic+197()
\o libvirtuos_sh.so:voDoAbortFuncs+37()
\o libvirtuos_sh.so:voSigAbort+167()
\o :__kernel_sigreturn+0()
\o libc.so.6:abort+257()
\o virtuoso:gliXIOErrorHandler+325()
\o libX11.so.6:_XIOError+45()
\o libX11.so.6:libm.so.6/PLT+2159027()
\o libX11.so.6:XFlush+49()
\o virtuoso:_Z12hiiSetCursorm+277()
\o virtuoso:hiiDiceCursor+47()
\o virtuoso:hiGetUserAbort+158()
\o libvirtuos_sh.so:voGetUserAbort+34()
\o libcdsIlIpc_sh.so:ipcxSleep+175()
\o libil_sh.so:iliVcodeEval2+21063()
\o libil_sh.so:ilxSkillEval2+216()
\o libil_sh.so:iliLoadPort+1431()
\o libil_sh.so:iliVcodeEval2+26932()
\o libil_sh.so:iliEvalString+611()
\o libil_sh.so:_ilErrSetString+235()
\o libil_sh.so:ilErrSetString2+60()
\o virtuoso:hiMainLoop+404()
\o virtuoso:_ZN3rde15startHiMainLoopEv+2619()
\o virtuoso:Tcl_Main+781()
\o virtuoso:_ZN17TclCommandAdaptor8mainLoopEiPPcPKcRKSt6vectorI9ctuStringSaIS5_EEPFvvE+591()
\o virtuoso:_Z11finaleEntryiPPcPKcbP16finaleAppHarness+3885()
\o virtuoso:_Z12rdeStartMainiPPc+61()
\o virtuoso:main+997()
\o virtuoso has encountered a fatal internal application error and will now exit.
\o A crash report file for this error can be found at: /tmp/crashReport_031511_1758_IC6.1.4.500.1_wonyoung_vasuki.eecs.harvard.edu.log
  • skillUser
    skillUser over 15 years ago
     Hi Wonyoung,
    Please enter a Service Request - I could not find a similar looking stack trace in our problem database after a quick search, so it is probably best to file an SR with Customer Support.  I can see that you are at a US University, so if you are not one of the contacts who is able to file an SR, please ask a professor or other contact.
    Best regards,
    Lawrence.
  • NicolasP
    NicolasP over 11 years ago
    Hi Lawrence,
    I am experiencing the exact same problem with the new AMS utility 'runams' that is available since IC 5.1.41 ISR 138, IC 6.1.3 ISR 14.
    I run concurrent runams commands and i see some kind of contention happening because I am randomly getting the following error for some runs:
    Running :  runams -lib $LIBNAME -cell $CELLNAME -view $VIEWNAME -netlist all -rundir . -cdslib $CDS_WORKAREA/setup/dfII/$PROJECT.cds.lib
    STDERR: IO Error 32 (Broken pipe) on Display "clvclo10:80.0"
    Exit code: 6
    In my example, when I run 12 runams calls in parallel using separate directories with separate logfiles and separate CDS.log files (on different topcells),  I get the 2 or 3 random fails (different cell each time).  If I run the same 12 runams calls serially, they all execute to completion without any problem.  I suspect that runams is falling victim the same problem as described by the user since it is basically a wrapper to virtuoso.
    I have a testcase to provide to R&D if that helps ...
    cheers
    Nicolas
  • NicolasP
    We can recommend to customers to use a grid computing solution to dispatch their ocean/runams jobs on different hosts. In my case, I introduced LSF calls into my simplan to randomize the hosts, and it solved my problem by greatly reducing the likelihood of contention.
    Nicolas - you should contact customer support so that this can be investigated.
