  3. SKill procedure to select and/or delete text notes from...
  • Subscribers 152
  • Views 4257
SKill procedure to select and/or delete text notes from schematic
jasons
jasons over 15 years ago
 I want to write a skill procedure to run on a schematic to delete all "text note" (or is it note text?) that matches a pattern--without having a bunch of menus popping open.  The pattern part isn't the problem, it's trying to select/delete the notes (these are not attached to any devices, they just float in the schematic).  Any help would be much appreciated.
  • Quek
    Quek over 15 years ago
    Hi Jason
    How about something like this?
    procedure( CCSdeleteNoteText(pattern)
       let( (cv allNoteText count)
          cv=geGetWindowCellView()
          allNoteText=setof(x cv~>shapes (x~>objType=="label" && !x~>parent))
          count=0
          foreach( text allNoteText
             when( rexMatchp(pattern text~>theLabel) dbDeleteObject(text))
             count++
          ) ;foreach
          printf("Total of %n note text deleted\n" count)
       ) ;let
    ) ;procedure
    Best regards
    Quek
  • jasons
    That's just what I was looking for!  Thank you very much.  For future reference is there a manual where I can learn about the CellView object?
    --Jason
  • Quek
    Hi Jason
    You can refer to "Attribute Retrieval and Modification" section in the manual "Virtuoso Design Environment SKILL Reference". It is located at $CDSHOME/doc/skdref/skdref.pdf.
    Best regards
    Quek
  • jasons
    Quek--
    Thanks again!
    Jason
