  3. awvSetWaveNameList broken in 6.1.5?
  • Subscribers 152
  • Views 15623
markbeck
markbeck over 15 years ago
I'm playing around with 6.1.5 and I tried the following experiment with a plot window.
 awvSetWaveNameList(awvGetWaveNameList(awvGetCurrentWindow()))
I would expect that it would return a 't', as all I'm doing is setting the current wave name to the current wave name.
But, I get back the following:
ERROR (WIA-1002): The specified waveform window ID is not valid. Specify a valid waveform window ID.
nil
I can do it more explicitly:
g_window = awvGetCurrentWindow()
window:18
 l_list = awvGetWaveNameList(g_window)
((1 3)
    ("/iref" "/I0/iref")
awvSetWaveNameList(l_list)
nil
Anyone else seeing this?
Mark
  • Quek
    Quek over 15 years ago
    Hi Mark
    Thank you very much for the detail description. There is indeed something wrong with the function. I am also seeing the problem in IC615-500-1.The windows argument is supposed to be optional but the function now insists that user provides a window ID. This issue has already been reported and will be fixed. As a workaround, please use the following for now:
    awvSetWaveNameList(awvGetWaveNameList(awvGetCurrentWindow()) awvGetCurrentWindow())
    Best regards
    Quek
