  3. Identify a waveform's full Y axis labels?
  • Subscribers 150
  • Views 1998
markbeck
markbeck over 15 years ago
I am trying to determine what a waveform viewer's Y-axis is labeled, however I'm having trouble with awvGetYAxisLabel()
First example:
I am viewing a waveform with voltage on one axis labeled "V (V)", and current on the other axis labeled "I (uA)". If I then issue the commands:
awvGetYAxisLabel(awvGetCurrentWindow() 1)
awvGetYAxisLabel(awvGetCurrentWindow() 2)
I get back "V" and "I" respectively.  This is all fine and good.
Second example:
I have an ac plot with voltage magnitude "Mag (mV)" on one axis and a current magnitude "Mag (uA)" on the other. If I issue the same commands I get back: "Mag" and "Mag".  Not exactly descriptive of what is plotted on which axis.
Is there any way to get  the entire Y-axis descirption back from the waveform viewer?
 Mark
    Mark,
    Most likely the right answer is to use yvec=drGetWaveformYVec(waveObject) and then yvec~>units and yvec~>name
    For your specific question though, it might help to know which version of the tools you're using, and which waveform viewer (in the case of IC5141).
  • markbeck
    Sorry, I'm using IC6.1.5.500.1
     So the issue is that I don't have access to the waveObject.  I'm trying to determine what's currently in the"Visulization & analysis" current window.
    Clearest example:
    w_plot = awvGetCurrentWindow()
    y_axis = awvGetYAxisLabel(w_plot 1)
    If I could query the viewer and get back a list of the actual waveObjects, that would be optimal (but I've asked that question before and been told that there currently isn't a method to accurately do this).
    Mark
