  3. common lisp features in SKILL
  • Views 16382
tashah
tashah over 15 years ago
I am unable to use some of the common lisp features in SKILL. For example, I want to define following function: (defun myFunc ( a b @optional ( c 10 cSuppliedP) ;; cSuppliedP indicates whether argument is actually passed or not (list a b c cSuppliedP) Similarly, some other functions like push and pop from DPL and format function to print in specific format. Is there any way to find how common lisp (or franz lisp) functions are mapped into SKILL? For example, macroexpand-1 is mapped to expandMacro. Can anybody help with this? Thanks.
  • skillUser
    skillUser over 15 years ago
     Hi Tashah,
    First, I am not familiar with "cSuppliedP" for a function argument.  I think that you would have to code this sort of behaviour yourself, something like the following:
    (defun myFunc ( a b @optional (c 'undef))
      (setq cSuppliedP nil)
      (if (eq c 'undef)
        (setq c 10)
        (setq cSuppliedP t)
      ; ... rest of procedure, c either has default value and cSuppliedP is nil
      ; or it has the supplied value and cSuppliedP is true
    As far as I know "push" and "pop" work with lists but are not documented, pushing and popping from a dpl interferes with the initial "nil" of the dpl list structure, so I don't think these work as they stand.  I should be relatively easy to implement this behaviour though?  For formatted print output you can use printf.
    I apologise if this does not help much, but I am familiar with SKILL but unfamiliar with common lisp.  There is a "Scheme/SKILL++ Equivalents Table" in the documentation, this may help a little?
    Lawrence.
  • tashah
    Thanks Lawence, it was quite useful. So, I guess my problem is when I use "Cadence SKILL API Finder", I am not finding these functions. As you said push and pop is supported, but they do not appear in search results.
    'undef is the new thing that I learned, thanks.
  • skillUser
     Hi Tashah,
    I should point out that "'undef" has no special meaning, it is just a value that the user is unlikely to supply, so when they do supply a value you can detect it.  Unfortunately this method would spoil the type template, for example if the type template for the function was "nnn" to indicate that a, b and c are to be supplied as numbers, then the default value 'undef of c would break this.  In this case you could just test in the code to see if the value of "c" is the same as the default - it does not detect whether the default was supplied though (would you need to detect this?), for example:
    (defun myFunc (a b @optional (c 10) "nnn")
      (if (equal c 10) (setq cSuppliedP nil) (setq cSuppliedP t))
      ; .. rest of code
    The type template is a very useful feature, make use of it if you can.  If the user supplies something other than a number type (float or integer are acceptable here) then the function fails with a clear message. Other characters that can be used for the type template are things like "t" for a string, "l" for a list, "g" for general (anything), "x" for an integer (or 'fixnum'), "f" for a floating point ('flonum').
    I hope that this helps you.
    Lawrence.
  • tashah
    That is very valuable function. Thanks a lot.
