  3. How to generate a string within backslash \ ?
  • Views 17270
Charley Chen
Charley Chen over 15 years ago
Hi All,
In spectre format , a net name is  XIop\/net23  // a backslash \ and a slash / ,
net1 = "XIop"
net2 = "net23"
aList = list("XIop" "net23")
I try to use buildString(aList "/") => "XIop/net23" , this is not what I want.
I try to use buildString(aList "\/") => *WARNING* (Parser) character found after backslash is not meaningful - \/    //I want this.
How to do it ?
Thank you,
Charley
    Charley,
    Backslash has special meaning in SKILL (it's the escape character) and so you need to escape it. So you'd use:
    out=buildString(aList "\\/")
    Don't be worried about the fact that when you look at the variable out, it's displayed as:
     "XIop\\/net23"
    That's simply because that's the "print representation" for this. If you use:
    printf("The net name is '%s'\n" out)
    You'll get:
    The net name is 'XIop\/net23'
  • Charley Chen
    Andrew,
    Thank you very much to clear the question .
    Charley
