  3. ocnPrint header?
  • Views 14663
ocnPrint header?
imagesensor123
imagesensor123 over 15 years ago
   I run a parametric analysis and use ocnPrint(?output "test" singlePointVout) in my script and get the result like the following txt:
iteration_swee    value((v "Vpixel" ?resultsDir "/home2/zfeng/Cadence/Techno035/Sim/pdpixel/spectre/schematic" ?result "tran") 4e-06) (V)
1                     1.01147
2                   797.174m
3                   669.963m
4                   547.271m
5                   427.882m
6                   863.587m
7                   732.847m
8                   863.587m
9                   608.164m
10                  157.674m
11                  256.493m
the waveobject is singlePointVout , if we can use the fprintf function with the waveObject to output this text file?is there a better way to print the result into a file in specific format, I intend to get the txt like this:
iteration_swee    value((v "Vpixel" ?resultsDir "/home2/zfeng/Cadence/Techno035/Sim/pdpixel/spectre/schematic" ?result "tran") 4e-06) (V) I don't need this information line , or it can be replaced by user define
1 --->real parameter value,such as  20u                    1.01147
2 --->10u                  797.174m
3 --->5u                    669.963m
4  ...                 547.271m
5  ...                 427.882m
6  ...                 863.587m
7  ...                 732.847m
8  ...                 863.587m
9  ...                 608.164m
10 ...                 157.674m
11 ...                 256.493m
i mainly want to clean the information line,
zfeng
