  3. How to modify the x1,y1 and x2,y2 coordinates of a rectangle...
  • Subscribers 152
  • Views 1342
How to modify the x1,y1 and x2,y2 coordinates of a rectangle in cadence layout using skill script:
soman
soman over 15 years ago
Say, in the layout below, I need to push upward the N well boundary and the bottom of P active and top of N active, by a certain small value.
I need all other polygons and layers intact in the layout.
                             PR boundary
             |   ______________   |
             |  |    P active       |  |  Nwell
             |  |______________|  |
             |--------------------------|  Nwell Boundary
             |   ______________   |
             |  |   N active        |  |
  • Slayer
    Slayer over 15 years ago
     If I correctly understand you question, you need simple modify the bbox of shap. For example, take all shapes which were created in active drawing layer and change bbox:
    foreach(shape setof(i geGetEditCellView()->shapes car(i->lpp)=="OD") shape~>bBox = list(car(shape~>bBox) caadr(shape~>bBox)+5:cadadr(shape~>bBox)+5))
     And as result for all shapes upperRight coordinate will be increased on 5udr
