  3. How to know the name of the properties of the device without...
  • Views 15915
How to know the name of the properties of the device without editing this property?
dell1
dell1 over 15 years ago
For example: I want to know the name of length and width properties of the nmos without editing in these properties(its length and width) then using nmos->prop->??  that show me an array like the following
("l" value "5u" valuetype "string" -----------) ("w" value "5u" valuetype "string")
but the problem is that these names(l, w) are technology dependent, so I want in my code to know these names in any technology
so as to make my code technology independent .
Thanks in advance.
    Given that both the property name (w and l in your example) and the prompt for these properties (defined in the CDF for the component) are technology specific, I can't see how you can do this without storing a mapping somewhere as to the property names that you're interested in for that technology.
    There is nothing special to Virtuoso about w and l. They called be called anything, and could mean anything.
    You might be able to look in the propMapping in the spectre simInfo in the CDF to see what gets netlisted as w and l, but even that's not reliable because the parameter that gets output may be one computed by a CDF callback, and thus there would be no way to know what the source parameter was from which they were derived.
    Best Regards,
