  3. Removing write protect to user-defined functions
  • Subscribers 150
  • Views 16546
cessej
cessej over 15 years ago
If i set write protect to my procedure using setFnWriteProtect, how can I remove it?
    Unfortunately there's no public SKILL function to do this directly, however, if you do:
    sstatus(debugMode t)
    then you can redefine any write protected SKILL function - in other words, when in debugMode, the write protection is ignored.
  • cessej
    Thanks Andrew for the information. With that, my script will be look like this.
    check function if protected (getFnWriteProtect)
    debugMode to t if protected
    update function
    set debugMode to nil.
