  3. problem with flattening
  • Subscribers 150
  • Views 14923
Aritra
Aritra over 15 years ago
   I am facing some issue with flattening. There are certain cells in my layout that when ever I try to flatten the icfb gets closed. It generates some panic (some panic is prompted to the CIW) and closes everything. I have tried leHiFlattenInst leFlattenInst dbFlattenInst . None are working. I have even tried to copy the subcell's containts to the main cell, this also generates the panic and the icfb gets closed.
Can anyone help me with this?
    You should log a service request for this with http://support.cadence.com .
  • Aritra
                     I have found an alternate solution to my prob. The solution is to use Yank and Paste.
