  3. Equivalent of leIsContact in IC6
  • Subscribers 150
  • Views 14801
cessej
cessej over 15 years ago
Anyone who knows the equivalent of leIsContact in IC6, or a function applicable for both
IC5 & IC6?
  • Aritra
    Aritra over 15 years ago
    Hi  cessej,
                   I have made a code for this purpose. Check it out.
    procedure(leIsContact(id)
    prog( ()
        if(id~>objType=="stdVia" then return(t)
        else return(nil)
            );if
        );prog
    );procedure SsContact
  • cessej
    Hi Aritra,
     Thanks for the reply.
    I added fboundp check so I dont have problem in IC5&IC6.
    unless(fboundp('leIsContact)
       <your code here>
