  3. can we define some component's parameter as a design variable...
  • Subscribers 152
  • Views 1509
can we define some component's parameter as a design variable by skill function?
imagesensor123
imagesensor123 over 15 years ago
   did you try defining some parameter as a design variable by skill function, for example, i have a transistor (M1) in my design, and i want to define the chanel length of M1 as a design variable "chanelLength", can we do that without interface, and just using skill command?
welcome to any discussion!
zfeng
  • Quek
    Quek over 15 years ago
    Hi zfeng
    Perhaps you are looking for this?
    instID~>L="chanelLength"
    where "instID" is the database ID of the instance. Just a gentle reminder, please remember to state the following in your question:
    a. The tool which you are using. E.g.
     - Virtuoso Schematic Editor L/XL
     - Analog Design Environment L/XL/GXL
     - Virtuoso Layout Suite L/XL/GXL
     - etc
    b. The specific version of the tool (execute "virtuoso -W" or "icfb -W" in a terminal window). E.g.
     - IC5141.500.6.147
     - IC615.500.2
     - etc
     Simply stating IC51 or IC61 is not very uesful. : )
    Best regards
    Quek
