  3. How to change output signals prior simulation in the batch...
  • Views 14128
How to change output signals prior simulation in the batch mode
Vitaly Rubin
Vitaly Rubin over 15 years ago
Hi
I have a list of pins extracted from a netlist. My target is collecting AVG values of current for all of them delivered by measuring during the analog simulation. The simulation is invoked by ADE in non-GUI mode or by OCEAN.
The simulation settings are given i.e. I'm not allowed to change any settings besides the delivered pins/nets. The simulation originally can include it's own list of pins and nets: I would like to disable all of them (if any), disable all plots (if any) and add my own list of pins. Then to kick off the run. The waveforms delivering aren't required, only measuring are mandatory.
All that should be done automatically w/o GUI in ADE/ADEXL when only session/test/pin list are provided.
Can you provide me any example/s how it can be done? Specifically how does it possible to eliminate all given signals nevertheless what they are and establish another set?
