  3. linereadstring() function problem
  • Views 17646
tyanata
tyanata over 15 years ago
I have such problem in my SKILL code. In one of the routines of it I create list of strings. And after that read them one by one and transform to symbols with the linereadstring()  function.
I have such a proble for example:
llinereadstring("x")
returns  ->(x)
llinereadstring("X")
returns  ->(X)
llinereadstring("9")
returns  ->(9)
llinereadstring("X9")
returns  ->(X9)
llinereadstring("9X")
returns  ->
SYNTAX ERROR found at line 1 column 2 of file *string*
*Error* lineread/read: syntax error encountered in input
My question is how can I overcome this problem if some of the strings in the list is starting with digit and ends with letter as "9X" in the example above.
Best regards,
tyanata
    tyanata,
    linereadstring() is really intended for parsing things that look like SKILL, and "9X" doesn't...
    So if it's a list of whitespace separated strings you want, you could use parseString() to convert to a list, and concat or stringToSymbol to convert them to symbols. For example:
    str="X9"
    mapcar('concat parseString(str))
  • tyanata
     Thanks for the response,
    The solution which you provided works but now new problem appears. I create togglefield (hiCreateToggleField) application form using this list of symbols. But when try to enable or disable symbol which is analog to string "9x" again the same problem appears.
    SYNTAX ERROR found at line 1 column 35 of file *string*
    Why I need this functionality. Because in my script some of the project libraries have to be skipped from processing. So the user to be able to choose which of the libraries to be skipped using GUI. And the problem is that most of libraries in the projects are called with names like 901243ABC .
    Can you propose how to solve the problem with the togglefield.
    Best regards,
    tyanata
    Tyanata,
    I can't see why you would need to have symbols the same as your library names to do this. I can't guess what your problem is without seeing the code (or something representative of it), so unfortunately it's hard for me to assist without some clue as to what the code is doing.
    Can you post the code so that I (or anyone else) can see what the problem is?
    Best Regards,
  • tyanata
     Hello Andrew,
    Here I post routine similar to the original  routine in my script. In this routine you can select which from the available in the certain project libraries to be included in the output procedure: DIG, IO, ANA and 90123AATOP in the example. In this example the output procedure is just printing: printf("List of libraries to be skipped:%s\n" xxx).
    To execute the routine start the function:  Choose_skip_lib()
    You can see that you can select and unselect each library except  90123AATO. If you select or unselect it error message appear:
     SYNTAX ERROR found at line 1 column 38 of file *string*
    procedure( Choose_skip_lib()
    ;       Description
    ;       Available project libraries: DIG, IO, ANA and 90123AATOP
            lib_list = list("DIG" "IO" "ANA" "90123AATOP")
            lib_list_length = length(lib_list)
            count_mem_list = 0
            l_libs=list()
            while( count_mem_list != lib_list_length
                    lib_member = car(lib_list)
                    lib_list = cdr(lib_list)
                    lib_member_symbol=list(stringToSymbol(lib_member))
                    l_libs=append1(l_libs lib_member_symbol)
                    count_mem_list++
            ) ;; close while
            l_fields_skip = list()
            l_TField1_skip = list( hiCreateToggleField(
            ?name 'TField1_skip
            ?prompt ""
            ?choices l_libs
            ?itemsPerRow 2
            ?value '(nil nil nil nil)
            ;?numSelect 6
            ?callback list("" "" "" "")
            ) 10:10 30:20 0)
            l_fields_skip=append1(l_fields_skip l_TField1_skip)
            hiCreateAppForm(                ;create Form
            ?name 'SkipLibForm
            ?formTitle "Choose lybraries to be skipped"
            ?fields l_fields_skip
            ?buttonLayout  'OKCancel
            ?buttonDisabled '(Defaults Apply Help)
    ;        ?initialSize '(560 630)
    ;        ?initialSize t
            ?minSize '(300 120)
            ?callback '( "CCSskip_lib_app_formApplyCB(l_libs)")
            hiSetFormPosition(  (xCoord(hiGetMaxScreenCoords())/2)-560/2 :
                                                    (yCoord(hiGetMaxScreenCoords())/2)-200  )
            hiDisplayForm(SkipLibForm)
    procedure( CCSskip_lib_app_formApplyCB(SkipLibForm_lib_name)
       let( ()
        SkipLibForm_lib_op = SkipLibForm->TField1_skip->value
        SkipLibForm_lib_name_length = length(SkipLibForm_lib_name)
        count_mem_lib_name_list = 0
        temp_lib_str_list=list()
        while( count_mem_lib_name_list != SkipLibForm_lib_name_length
                t_key = car(SkipLibForm_lib_name)
                SkipLibForm_lib_name=cdr(SkipLibForm_lib_name)
                t_val = car(SkipLibForm_lib_op)
                SkipLibForm_lib_op = cdr(SkipLibForm_lib_op)
                t_key_i = car(t_key)
                if( t_val==t then
                temp_lib_str_list=append1(temp_lib_str_list t_key_i)
            count_mem_lib_name_list++
            ) ;; close while
        skip_lib_final_string = buildString(temp_lib_str_list)
        printf("List of libraries to be skipped:%s\n" skip_lib_final_string)
       ) ;let
    ) ;procedure
    I modified the code - and added some comments - to show how to do this. The problem was that if you simply used the toggle field symbols as prompts, it expects the symbols to be legal names, which they aren't. This is easy to resolve - I also removed some of the less efficient parts of the code (see comments).
    let((lib_list l_libs l_fields_skip l_TField1_skip)
    ; Description
    ; rather inefficient way of converting a list of strings to a list
    ; of symbols
    count_mem_list = 0
    l_libs=list()
    count_mem_list++
    ) ;; close while
    ; Convert list of libraries to a list of symbols and strings. The symbol begins with
    ; tog_ so it has a legal name, and the second entry in the list is the prompt
    l_libs=foreach(mapcar libName lib_list
    list(concat('tog_ libName) libName)
    ?name 'TField1_skip
    ?prompt ""
    ?choices l_libs
    ?itemsPerRow 2
    ;?numSelect 6
    ) 10:10 30:20 0)
    ?name 'SkipLibForm
    ; ?initialSize t
    ?minSize '(300 120)
    ?callback 'CCSskip_lib_app_formApplyCB
    ; Record the list of libraries on the form (avoids a global variable)
    SkipLibForm->lib_list=lib_list
    procedure( CCSskip_lib_app_formApplyCB(form)
    let( (temp_lib_str_list skip_lib_final_string)
    ; Use setof with two lists - the first list is the names of the library
    ; to filter, whereas the second is the list of toggle values.
    temp_lib_str_list=setof((libName togField) form->lib_list form->TField1_skip->value togField)
    ; inefficient way of finding out the library names
    if( t_val==t then
    ) ;; close while
    ) ;let
    ) ;procedure
  • tyanata
    The proposed solution works perfectly!
    Best regards,
    tyanata
