  3. dbReplaceProp with a mosaic
  • Views 16784
jutburkhart
jutburkhart over 15 years ago
I am using the following skill code to generate a mosaic of transistors:
dbMOS = dbCreateSimpleMosaicByMasterName(pcCellView procLib "nldmos_hs" "layout" "M1" 0:0 "R0" Ncols Nrows DevHeight DevWidth)
I want to set parameters of the cell nldmos_hs. When using dbCreateInstanceByMasterName to instance a single transistor, I use dbReplaceProp. However, I cannot figure out how to do the same when instancing a mosaic.
Also, in the icfb window I get a warning when creating the mosiac: *WARNING* invalid instance -- 527567744(mosaic).
Not sure if the two are related. Any help is appreciated!
Justin
  • jutburkhart
    Ok, so I answered my own question.
    The command needed is dbCreateParamSimpleMosaicByMasterName. This command isn't listed in the manual, but it exists.
  • skillUser
    skillUser over 15 years ago
     Hi Justin,
    It is documented - perhaps it is not in the release that you are using though?  I grabbed this from the IC615 documentation on COS:
    dbCreateParamSimpleMosaicByMasterName( d_cellView t_libName t_cellName t_viewName t_name l_origin l_orient x_rows x_cols x_rowSpacing x_colSpacing l_params ) => d_mosaic | nil
    I hope this helps a little?
    regards,
    Lawrence.
