  3. How to chop hierarchical ROD object?
  • Views 16839
Slayer
Slayer over 15 years ago
 Hi all!
Could you pls. help me with chopping of the rod objects. The question is I have Instance with RodObject.
 To find this object inside instance I use rodGetOb:
 cv = geGetEditCellView();
gRing = rodGetObj("GuardRing1/GuardRing" cv); Where GuardRing1 - istanceName, GuardRing - name of the rod object;
after that, I  catch all layer on top level and take only m1 layers:
 metStripes = setof(i cv->shapes i->lpp == list("m1" "drawing"));
find m1 path rings in rod object:
 m1SubPath = setof(i gRing->subShapes car(i->lpp) == "m1");
after that, finding common part (metal intersection)  and calculate centerline point and try to make chop, for example:
 rodAddMPPChopHole(gRing list(44.44:19.36 44.44:18.85));
But have in CIW following warning:  *WARNING* rodAddMPPChopHole: objId rodObj:0x14b6a18c: hierarchical ROD object not allowed - name is "GuardRing1/GuardRing"
And nothing happend :(
    It makes no sense to chop a shape within the sub-cell, surely? What if you have two instances of the block containing the guardring - and hence GuardRing1/GuardRing and GuardRing2/GuardRing ROD objects. If you were able to call rodAddChopHole on the first of these, it would modify the second too - which presumably would not be what you want - because they are in the same cell.
    I think you'd have to flatten the instance of the cell containing the guardring first before you can add a chop hole. Or open the lower level cell (in SKILL), and then do a rodGetObj("GuardRing" lowerCv) and chop that.
  • Slayer
     Thx. you Andrey!
