  3. errset command question
  • Views 15854
boyg
boyg over 15 years ago
 Good day,
 I have a concern regarding errset command when used in calculator (CALC) commands; I want to contain CALC errors into a list. In the example below, when I invoke
                                  errset("clip(v("net31" ?result "timeSweeptran") 1u 2u)")
to "catch" the error using errset, the result is
                                 errrset("clip(v("net31" ?result "timeSweeptran") 1u 2u)")
                                 SYNTAX ERROR found at line 29 column 23 of file *civInPort*
                                 *Error* linread/read: syntax error encountered in input
I follow it with
                                  errset.errset
 to see the list that contains the error but the result is (nil). Here, I only want to get errors of CALC functions (cross, average, clip, abs). How do I solve this problem? Your suggestions and comments would be of great help. Thank you very much.
  • boyg
     Good day,
     I have a concern regarding errset function when used in CALC functions; I want to contain CALC errors into a list. In the example below, when I invoke
    I follow it with
                                      errset.errset
    First of all, please do not post the same question to more than one forum, because nobody knows which one has been answered - you're more likely to annoy people and reduce the chances of getting an answer. If the post is in the wrong place, I will tend to move it to the right place as forum moderator. So in this case I've joined your two posts...
    Two problems. In your example you spelt errset as errrset. The bigger problem is the fact that you've put the expression in quotation marks, and because of that you have ended up with incorrectly matched quotation marks and hence you're getting the syntax error during parsing - so the errset hasn't even been called at that stage. What you want is:
                                      errset(clip(v("net31" ?result "timeSweeptran") 1u 2u))
    Best Regards,
