  3. Not able to create rectangle over via in hierarchy
  • Views 15630
savvysaggi
savvysaggi over 15 years ago
I am working on one skill which creates metal rectangles on via  in hierarchy.
cv=geGetEditCellView()
;println(cv)
listsofar=list()
procedure(TrHierarchyTransversal(cv listsofar)
;cv=geGetWindowCellView()
;println(cv~>instances~>master)
foreach(master cv~>instances~>master
let((nextcellview)
nextcellview=master
cond(
(!nextcellview nil)
(member(nextcellview listsofar) println("its member"))
(t
if(!listsofar
then
a=car(setof(via cv~>vias via~>viaHeader~>viaDefName=="B2YZIA"))
        ;println(a~>viaHeader~>viaDefName)
    pbox=a~>bBox
            dbCreateRect(cv "M6" pbox)
);if
listsofar=TrHierarchyTransversal(nextcellview cons(nextcellview listsofar))
cv1=(car(listsofar)~>cellView)
;println(cv)
a=car(setof(via cv1~>vias via~>viaHeader~>viaDefName=="B2YZIA"))
    pbox=a~>bBox
            dbCreateRect(cv1 "M6" pbox)
;);if
);t
);cond
);let
);foreach
listsofar
);procedure
ISSUE:
I this skill , it creates rectangle on via according to hierarchy level (eg. If via is present till 4th hierarchy of top then it creates rectangle over via four times)
Kindly check for the same as i am unable to catch the issue .
Kindly help me out.
Thanks & Regards
Savvy
  • kb how
    kb how over 15 years ago
    Hello Savvy,
     Can you explain more on what you're trying to do with the script. Without knowing the function of the script is constructed, it is hard for us to troubleshoot.
  • savvysaggi
    1)Hello Kb,
     With the use of skill code , I want to do the following task:
    1) 1)Search all the cells hierarchically and see if any cell has any via with name “B2YZIA”.
    2) 2) If such via exist in the cell create a metal rectangle on it.
    Hope it is clear to you.
    Thanks & Regards
    Savvy
  • kb how
    Hi Savvy,
    On top of your coding, i did some modication as your request. Please refer below. At the same time i added some comment on it for each step.
    procedure( TrHierarchyTransversal(cv listsofar @key save)
       let((vias cvId pbox)
          ; Foreach every instanceMaster
          foreach(master setof(x cv~>instanceMasters !member(x listsofar))
             ; Store cell that visited
             listsofar = cons(master listsofar)
             ; Check whether the cell got via or not
             when( (vias = setof(via master~>vias via~>viaHeader~>viaDefName=="B2YZIA"))
                ; Via found. Open cv in edit mode
                if( (cvId = dbOpenCellViewByType(master~>libName master~>cellName master~>viewName nil "a")) then
                   foreach( via vias
                      pbox = via~>bBox
                      dbCreateRect(cvId "M6" pbox)
                   );foreach
                   ; Save it
                   when( save
                      dbSave(cvId)
                   );when
                else
                   ; Failed to open, print warning msg
                   warn("Failed to open cellview in edit mode.[%L %L %L]\n" master~>libName master~>cellName master~>viewName)
                TrHierarchyTransversal(master listsofar ?save save)
             );foreach
          );foreach
       );let
    );procedure
     This is just a scratch coding, you may need to enhanced it as well.
    Happy testing
